Mar 06, 2017
05:54 AM
Mar 06, 2017
05:54 AM
Hello everybody,
I am using Hegagon XMC4500 dev board with Dave 4.3.2.
On Dave Release notes it is indicated that a new Window - View could show grafically
memory usage from elf / map files. But this does not seem to work for me :
Any idea why the fields remain empty?
Thank you for any hint.
Jorge
Jorge
Mar 08, 2017
12:32 AM
Mar 08, 2017
12:32 AM
Could you send us the log file you will find in your workspace? In your workspace, inside the .metadata, you will find a .log file.
Can you try also with the stand alone version of the tool? See attachment. Just uncompress and double click on the .jar file. It requires Java 8 being installed.
03:38 PM
Jan 18, 2018
03:38 PM
It is probably due to the length of the file path. I could display the elf analysis after copying the .elf file from my workspace folder to desktop.
