DAVE™ Forum Discussions
Hi all,
I'm using XMC 4500 and DAVE 3 for my project. For layout issue, I use USIC2CH0 and P5.0 to P5.4 as my SPI output. But I can not assign the USIC2CH0 in manual resource assignment. The pins P5.0 to P5.4 are also can not be found in manual pin assignment. Is it the limitation of SPI001[1.0.16]? How can I do to use this pins as SPI output? Thanks in advance
BR,
Morris.
I found the problem is caused by the different version of the MCU chip. There's no fifo in USIC2 module of XMC4500-F144x1024 step AA MCU, hence the resource USIC2CH0 cannot be assigned for SPI001 API.
