Mar 22, 2016
03:36 AM
Mar 22, 2016
03:36 AM
11:48 PM
Mar 22, 2016
11:48 PM
HI
For XMC4700 device, the number of slave select lines (SELOx) supported is 6.
Adding beyond 6 lines will result in the error that you have observed.
Daryl
Daryl
Jan 30, 2018
02:48 AM
Jan 30, 2018
02:48 AM
I also tried to change the slave select lines to "3", but I get the same error.
Even "2" select signals is not possible.
Does anyone have an idea?
Stefan
Stefan
Jan 30, 2018
05:29 AM
Jan 30, 2018
05:29 AM
Which other resources do you use in the project?
02:54 AM
Jan 31, 2018
02:54 AM
I use the ECAT APP and an ADC measurement.
So do you assume that these apps use the other slave select lines?
