Problem while debugging
After building my code, when i click on debug option , it is directly terminating without allowing me to click resume option. It is directly getting terminated. I am using DAVE version 4.3.2.
I faced the same problem. It was something wrong with the debug configuration. Please do the following in the debug configuration and give it a try.
  • Open Debug Configrations from the dorp down menu in the debug button
  • go to the startup tab
  • Scroll down and click reset defaults
It worked for me.
Best Regards
Suraj
