01:56 AM
Apr 29, 2015
01:56 AM
I have a problem with stopping PWM (PWMSP002 app). When I use "PWMSP002_Stop" function it works but inverted output goes to random state (sometimes it lasts ON, sometimes OFF). In my case both outputs must be cleared after stopping PWM. Can anybody tell me how to stop PWM and then immediately clear both outputs (inverted and direct output)?
Thanks in advance,
TM
Thanks in advance,
TM
02:46 AM
May 04, 2015
02:46 AM
Hi TM,
You may get some hints from DAVE Forum "Feature request : When PWMSP002 is stopped, set the outputs to passive level".
BR,
Zain
BR,
Zain
12:02 AM
May 13, 2015
12:02 AM
Thanks for link.
I already solved my problem. My solution is: two external AND gates driven by GPIO pin.
By the way: Setting/resetting ST signal suggested by P. Yélamos doesn't work in my case. Solution given by Aaron Walsh was not tested by me.
BR
TM
BR
TM
