PWMSP002 (1.0.12) Interrupts in Asymmetric Mode
Arno
25 replies posted 10 replies posted 5 replies posted
The PWMSP002 (1.0.12) makes use of CCU8 resource, hence it provides two compare values which are combined to build the output pattern in asymmetric mode. I also can configure the compare match interrput.
The question is: When is the interrupt generated? I do not find any selection for which compare value is to be used.
Thanks for any help.
Arno
