Dec 03, 2019
04:38 PM
Dec 03, 2019
04:38 PM
Hi
Using the XMC Pinout tool, I can select P0.2 as on output for CCU8 slice 0:
However I cannot select this pin using the PWM app in DAVE(only see P0.5). The PWM uses the CCU8 timer.
I tried this on a new project to eliminate a pin conflict from another APP as the cause of the issue. I have change the pin allocation in the generated code to P0.2 and it does function correctly. Is there something im not understanding ?
Dec 06, 2019
06:27 AM
Dec 06, 2019
06:27 AM
For which product and package?
04:41 PM
Dec 09, 2019
04:41 PM
XMC 4200, the 64 pin package.
Jan 09, 2020
09:21 AM
Jan 09, 2020
09:21 AM
Was there an update on this ?
Jan 13, 2020
05:25 AM
Jan 13, 2020
05:25 AM
The PWM APP is only using 1 of the 4 outputs of the slice, actually output 0. The Pin P0.2 is only available from output 1.
Try with PWM_CCU8 APP where you can select which output to use.
