04:25 AM
Mar 23, 2013
04:25 AM
I am trying to use the POSQE001 [1.0.12] app.
it works fine until I select SignalConfigurations->ExternalEvent->EnableClearOnIndex
Dave generates code with a not defined Macro in POSQE001_Conf.c:
const POSQE001_EventConfigType PosCntEvt2_Inst0 =
.EventType = POSQE001_EXT_STOP,
.ActiveEdge = POSQE001_EVT_RISING,
Also I think this macro should be set to POSQE001_EXT_STOP = 2. Even If I think this is not the right way to clear the counter on index.
Any Ideas how to get the counters cleared on every index ?
01:43 AM
Mar 27, 2013
01:43 AM
Hi VTrapp,
We had submitted a change request for this. Will let you know once it is fixed.
Meanwhile, I have forwarded your question on "how to get the counters cleared on every index" to my colleague who has experience on this.
Sophia
Sophia
02:12 AM
Mar 28, 2013
02:12 AM
Thanks Sopia,
meanwhile worked it out. Counters will be cleared on every index by doing the following
modifications:
// Einstellungen um in diesem Mode die Register mit jedem Index zu loeschen
// QDC |= 0x20 ICM all Index on OUT3
POSQE001_Handle0.PosifModulePtr->QDC |= 0x20;
CCU4SliceRegPtr = POSQE001_Handle0.CCUSliceConfigPtr[0]->SliceAddress;
// 0x00850054
CCU4SliceRegPtr->INS = 0x00950654; // EV2IS = CCU40IN0G, EV2M = Rising,
// 0x0001600
CCU4SliceRegPtr->TC = 0x00001500; // ENDM = Flush
CCU4SliceRegPtr->CMC = 0x0000480C; // CMC ENDS Event 2
this is just a quicky.
modifications:
// 0x00850054
// 0x0001600
03:40 AM
Sep 12, 2013
03:40 AM
I have the same problem. Where should i apply this modifications? Can you explain me better please?
Bruno
Bruno
02:23 AM
Sep 13, 2013
02:23 AM
Hi Bruno,
I think they should be placed in main.c after DAVE_Int(). Maybe just have a try...
Zain
Zain
08:44 AM
Sep 13, 2013
08:44 AM
Zain is right,
just put the code somewhere behind DAVE_Init().
12:30 AM
Sep 23, 2013
12:30 AM
I added the function static void POSQE001_lStartCCUSlice(const POSQE001_SliceConfigType* SliceConfigPtr) and it worked out!!!
Thanks a lot.
Bets Regards,
Bruno
Thanks a lot.
Bets Regards,
Bruno
12:30 PM
Sep 23, 2013
12:30 PM
In the end with your help i solved the problem. I added the code in the end of the function static void POSQE001_lStartCCUSlice(const POSQE001_SliceConfigType* SliceConfigPtr)
and it works.
Thanks a lot.
and it works.
Thanks a lot.
