11:21 PM
Apr 26, 2016
11:21 PM
Is there any (beta or final) component which are uses the POSIF module? I have tried some motor control example but it seems they aren't using the POSIF module.
I have tried for example this:
http://www.infineon.com/dgdl/Infineon-Motor_Control_Application_Kit_Getting_Started-GS-v02_00-EN.pdf...
08:14 PM
May 04, 2016
08:14 PM
HI,
We have published an application note to describe some usecases of the POSIF module.
You can refer to our application note on more details of the POSIF module. The link is below:
XMC1000 Product documents: http://www.infineon.com/cms/en/product/microcontroller/32-bit-industrial-microcontroller-based-on-ar...
XMC4000 Product documents: http://www.infineon.com/cms/en/product/microcontroller/32-bit-industrial-microcontroller-based-on-ar...
POSIF Application Note: http://www.infineon.com/dgdl/Infineon-POSIF-XMC1000_XMC4000-AP32289-AN-v01_00-EN.pdf?fileId=5546d462...
Daryl
Daryl
