An_1
5 replies posted 10 sign-ins 5 sign-ins
I used two SPI's (SPI 1 and SPI 2) to communicate with two different flashes(Flash 1 and Flash 2) which are same IC make. I configured both SPIs identically. I may able to communicate with SPI 1 and Flash 1 but not with SPI 2 and Flash 2. I used four SPIs in my code. Is there any setting which i have to do to communicate with the SPI 2 and Flash 2?
So please help me to resolve this issue.
Aashita_R
50 likes received 100 solutions authored 250 replies posted
Hi @An_1 ,
Can you please let us know the device you are using? This will help us look for the correct resources to guide you.
Aashita
An_1
Hi @Aashita_R
I am using XMC 4800 controller.
An_1
Hi @Aashita_R
I am using XMC 4800 controller which is 144pins and 2mb flash(XMC4800 F144x-2048).
Best Regards
Anirudh.
