Aug 28, 2014
08:38 AM
Aug 28, 2014
08:38 AM
12:08 AM
Sep 04, 2014
12:08 AM
Hi Daniel,
It is confirmed that both Apps cannot be used at the same time due to limited hardware resources (only one SysTick). The USBLD001 uses SYSTM001 for generating a delay which is necessary in the USB OTG protocol handling.
Sophia
Sophia
Sep 09, 2014
06:22 AM
Sep 09, 2014
06:22 AM
Solution for me is to use SLTHA002 with RTOS:
To get access to a USB Mass Storage device use SLTHA002, go to FATFS005, enable "USB (Drive #1)"
Daniel
Edit: you've also got to check "Use RTOS" in USBLD001
Daniel
