03:14 AM
May 19, 2013
03:14 AM
Hi Everyone,
I really stuck on how to create multiple channel on ADC,
I want to convert some motor control current and speed into digital signal with Queue Request Sources (ADC002), and also measuring the temperature with the background request resources (ADC001).
I have tried to work in ADC002 and add more channel, but i don't know how to proceed.
Anyone know how to do this?
your helps is much appreciated.
Thanks and regards,
Ali
Thanks and regards,
Ali
07:04 AM
May 21, 2013
07:04 AM
Hi Ali,
you simply select the number of channels needed inside the GUI of the ADC002 app. Then additional channel apps are aggregated automatically. Please use always the 'new instance' option when asked about the type of the new app.
Then background app does not make use of the channel apps, but consumes the hardware resource directly.
Arno
Arno
08:29 PM
May 22, 2013
08:29 PM
HI Arno, Thanks for replied
I did already what you said, but i couldn't create another instance for IO004. I want use IO004 as the output.
my idea is to use synchronous apps (ADC002).
is there any difference?
thanks and regards,
Ali
thanks and regards,
Ali
