11:27 AM
Sep 22, 2014
11:27 AM
DAVE 3.1.10 tries to access some URL which can't be served during start:
These files are not accessible (not found) on the server.
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC1300/CCU/CCUST001_Example1_XMC13.xml
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC4200/DMA002_Example1_XMC42.xml
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC4200/DMA003_Example1_XMC42.xml
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC4400/DMA002_Example1_XMC44.xml
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC4400/DMA003_Example1_XMC44.xml
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC4500/Service_01/DMA/DMA002_Example1.xml
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC4500/Service_01/DMA/DMA002_Example2.xml
Error while reading file http://dave.infineon.com/Libraries/Examples/XMC4000/XMC4500/Service_01/DMA/DMA003_Example1.xml
11:47 PM
Sep 22, 2014
11:47 PM
DAVE won't try to access the dedicated examples from server during start-up.
Is it the 1st time you use DAVE 3.1.10? Would you pls provide a snapshot of your DAVE "Library Update Sites" (Go to: >Windows>Preferences>Dave>Library Manager>Library Update Sites)?
Sophia
Sophia
