User9154
This Application has only possibilities to migrate inside subfamily XMC4800,
but a have (want) to use subfamily XMC4300...
When can it be possible?
best regards
zbyno
MichaelIFX
we do not plan to create the firmware update example also for XMC4300.
I propose to start with the XMC4300-project of the basic example ETHCAT_SSC_XMC43.
All the code you than can take over from the firmware update example of XMC4800.
You just need to be careful about the smaller flash size on XMC4300.
Kind Regards
Michael
User9154
Hi MichaelIFX,
Thank you, I will try to write my own app. I will show, if I have all correctly understood...?
Have a nice day
zbyno
