Hi @ all,
I am using Dave3 and XMC4500 for a new project. In this case we have four sub-projects which can run for test applications alone.
After the tests we would like merge the sub-projects in one DAVE3-CE project and generate the lib-code.
Is that possible? How can I solve this problem?
Thanks for your helpfulness.
Hi Johannes,
DAVE3 does not provide such feature.
I think the best way would be create a new project and copy the relevant files from the sub project into the new project.
Hi Jackson,
Thank you for the replay.
Witch files or folders from the sub projects shall I copy?
I use the NVIC002-App in both sub projects. How can I solve the problem?
Can I copy the S/W App Connectivity View and the H/W Connectivity View?
Hi Johannes,
It is recommended to rebuild a new project especially involving common Apps like your case.
Copying S/W App and H/W Connectivity View is not supported.
Sophia
