MaxECU
Welcome!
I'm trying to set-up PWM on XMC1100. For this I use PWMSP001 [1.0.26], but I cannot define more than 4 channels. Is that the device limitation or there is a way to define PWM on 8 / 16 channels?
Hi Massimo,
There is only one CCU4 module (4ch) in XMC1100. If you want more channels eg. 8ch, you should choose XMC1300. This info can be found in Infineon web-page.
Sophia
