User22089
I'm trying to use the LWIP apps in DAve (4.4.2) with the RTOS option on the XMC4700 relax kit. It works well when I select RTX as OS and add the requires user threads but I can't make it works whit FREERTOS selected.
Any Idea of what I should do to use FREERTOS?
User22175
I have the same problem on the XMC4500 relax kit. This is my RTX solution . With RTX it is working, but with FREERTOS, no chance.
You have a solution in the meantime?
MiroslavCZE
5 sign-ins 5 replies posted First reply posted
Hello guys, few years later it seems I have the same problem. Was you able to run in finally?
