11:49 PM
Feb 16, 2016
11:49 PM
hi,
after upgrade to DAVE 4.2.2 and install LWIP, i get an "Generate Code" error : in "File "ethernetif.tcmp"
"Cannot invoke method toInteger() on null object ethernetifc.tmpl /LWIP_TEST/Dave/Model/APPS/ETH_LWIP/v4_0_4/Templates line 498 Groovy Template"
out.print("""
port_control.clk_rmii = (XMC_ETH_MAC_PORT_CTRL_CLK_RMII_t)${eth_lwip_inst.hwres_eth_mac.getRegValue("con","con_rmii").toInteger()}U;
attached is the (XMC4700) DAVE CE Project.
Torsten
out.print("""
Torsten
Feb 17, 2016
12:43 AM
Feb 17, 2016
12:43 AM
Hi everybody,
I've noticed the same issue but only when I try to generate the code for a XMC4800. For XMC4500 the code Generation works.
Niclas
Niclas
06:51 PM
Feb 17, 2016
06:51 PM
Hi Niclas, Torsten,
I had the same problem initially. It seems that the device description was not installed properly in the previous update.
After I reinstalled the device description, it managed to work for me.
Here are the steps I did, can you try please:
#1) Select "Help -> Install DAVE APP/ Example/Device Library ..."
#2) In the Library Manager Wizard, select "Work with: DAVE APPs Library Manager"
#3) Uncheck the Filters "Hide items that are already downloaded", select "Library_DAVEDeviceDescription -> Dec_Release_2015_12_15". This will install the device description files for the product again.
#4) Create a new DAVE CE project and add the ETH_LWIP APP.
Daryl
Daryl
Feb 17, 2016
11:26 PM
Feb 17, 2016
11:26 PM
Hi Daryl,
thank you, now it works for me!
Niclas
Niclas
11:29 PM
Feb 17, 2016
11:29 PM
Hi Niclas!
Great! 🙂
Great! 🙂
01:53 AM
Feb 19, 2016
01:53 AM
Hi Daryl,
thank you, it works.
But is there a way to reinstall the devicedescriptiors for an existing (large) Project ?
...I found the answer myself: Make an "APP's Upgrade" to the project.
torsten
torsten
02:17 AM
Feb 24, 2016
02:17 AM
Hi Torsten,
Yes, you are absolutely right, it is possible to do a "DAVE Project Upgrade -> APPs Upgrade".
This can work if the project contains older versions of APP. During the upgrade to the latest available APP version, it will also update the latest files to the project.
Daryl
Daryl
