07:09 AM
May 29, 2014
07:09 AM
08:39 PM
May 29, 2014
08:39 PM
Hi Wonka,
Perhaps you can get some hints from GUISL001_Example1/2?
BR,
Zain
BR,
Zain
12:40 PM
May 30, 2014
12:40 PM
I looked at them, but they are for a graphic display which are connected differently.
I need 7 pins ( RW,RS,EN, 4 Data Bits).
I thought i could maybe adapt code from a AVR lib(e.g.), but i'm relatively new to Dave and have some problems with it because its hard to find good tutorials.
How can i set several pins at once ? for example when i want to send an asci code ( e.g. 0011) to the data pins ?
02:29 AM
Jun 02, 2014
02:29 AM
Hi Wonka,
Sorry, I have not experience on this:( What I can suggest is to take a look on the "LCD_X_DisplayDriver()" function in LCDConf.c.
BR,
Zain
BR,
Zain
06:21 AM
Jan 07, 2015
06:21 AM
Hello Everyone,
I have modified a 4-bit Library LCD library to be used with Dave tool and XMC based MCUs.
It needs GPIO App(IO004) to configure each pin as output and I have used a Timer AppSYSTM001 with millisecond resolution for delay routines.
I have tested this library with XMC2Go dev tool which is using XMC1100 MCU.
For me XMC2Go, is the smallest development board with an integrated debugger.
Library files are attached with this post.
It may help someone to connect these type of LCDs in future.
Aqeel
Aqeel
Dec 08, 2016
02:45 AM
Dec 08, 2016
02:45 AM
thanks aqeel for your useful library. I needed it for Dave 4 and the modified version is attached.
tested with:
* XMC1200 Boot Kit @5V
* 16x2 LCD, Displaytech 162C, KS0070B-compatible
* just add one SYSTIMER-App and 7 Digital_IO-Apps and rename them to p.e. IO_DB4 a.s.o.
br
tested with:
br
Oct 06, 2022
11:52 PM
Oct 06, 2022
11:52 PM
Hi
I used this code. Checked the output using evaluation board's LEDs, logic is working fine but the LCD doesn't give the output what I expect. This is how my LCD displays(attached). What/Where may be the issue? Any thoughts. (XMC 1400 Boot Kit, I am using)
