Is there a documented process for migrating code and Apps from DAVE to Keil uVision4
I may need to migrate my code and Apps from DAVE to Keil uVision 4 sometime in the future to allow me to look at code execution speeds in the Keil debugger.
I'm not entirely sure of the best way to do this without lots of trial and error. Is there a documented or recommended process to follow ?
I am using the xmc4500 device.
Any help and suggestions will be much appreciated.
Aaron
Hi Aaron,
Yes, the relevant info is available in DAVE Support Portal http://www.infineon.com/cms/en/product/promopages/aim-mc/DAVE_3_Support_Portal/Third-Party-Support.h...
Sophia
Fantastic. Thank you yet again Sophia.
Aaron
