User17492
5 sign-ins First like given Welcome!
When create a ECAT_SSC App v4.0.20 in DAVE 4, folder SSC contains a "patch.diff" file.
I tried to use in DAVE software, the Team->Apply Patch, Select the "Apply the patch to the selected file, folder or project
Selected the SSC/Src folder but the dialog get an error of (file does not exist)
Anybody successfully use this "patch.diff"?
Tac
.4184.attach
jferreira
5 sign-ins First like received 750 replies posted
The contents of the patch are described in https://www.ethercat.org/memberarea/forum.asp?../memberarea/forum/free-download-slave-stack-code-v5-...
To apply the patch, you copy the patch file into the SSC/Src folder after the SSC code generation and use the patch utility i.e. from Git for Windows
.../SSC/Src $ dos2unix.exe patch.diff
.../SSC/Src $ patch -b -p1 -i patch.diff
See patch --help for other options i.e. for backing up original files.
Alternatively using DAVE you can select the SSC folder, right click and select Team->Apply Patch.
jferreira
1. Select the patch file, right click and select Team > Apply Patch... in the context menu.
4185.attach
2. Select the resource to patch
4186.attach
3. Review patch
4187.attach
User20875
Hi Jesus,
I applied Patch, but TcXaeShell still throws error "FoE Err(0x8000)"
Could you provide zip with working project for ETHCAT_FWUPDATE_SSC_APPLICATION_XMC48, for Release and Debug.
"Getting Started - XMC4800_Relax_EtherCat_APP_FWUpdate_Slave_SSC_Example_V3.3.pdf" is not up to date - does not reflect SSC 5.12, or steps for patch.
Sergiy
