Jan 09, 2014
12:48 AM
Jan 09, 2014
12:48 AM
Hi all,
I need to use a table of const in my project. I need to locate this constants in concrete adresses on Flash.
What is the simpliest way to do this?
I tried create new section in Project Properties / C/C++ Build / Memory Settings Page
And use it in program like in gcc manual:
http://gcc.gnu.org/onlinedocs/gcc/Variable-Attributes.html
const uint8_t my_array[] __attribute__ ((section ("FLASH_2_uncached"))) = {0x01,0x02,0x03};
But it does'nt work 😞
#define MyValue (*(unsigned char *)(0x0C000100))
MyValue = 10;
This does'nt work too. I think that i will have to set linker, but I do not know how.
Any advice please?
MyValue = 10;
Any advice please?
- dave general
01:10 AM
Jan 10, 2014
01:10 AM
Hi David,
I've tried to place a variable in Flash_1_uncatched region [FLASH_1_uncached(RX) : ORIGIN = 0x0C000000, LENGTH = 0x100000].
In *.ld,
In main.c,
Perhaps you can try to adapt to your case?!
BR,
Zain
In *.ld,
Uncached_Code ABSOLUTE(__exidx_end | 0x04000000):
Uncached_Code_Start = .;
* (Uncached_Code);
. = ALIGN(4);
Uncached_Code_End = ABSOLUTE(.);
} > FLASH_1_uncached
/* CONST data section */
.rodata ABSOLUTE(Uncached_Code_End): AT(Uncached_Code_End | 0x04000000)
In main.c,
unsigned int MyData __attribute__ ((section("Uncached_Code")));
MyData = 0xAA;
BR,
Zain
Jan 10, 2014
03:20 AM
Jan 10, 2014
03:20 AM
Thank you very much!
It works perfectly 🙂
