12:26 PM
Feb 07, 2017
12:26 PM
I am working with Dave v4.3.2 on an XMC4000 type of processor.
I would like to fill the RAM with a repeated pattern and then dump it after my program has run for a while.
How can I do it? The closest I have seen so far is to open a memory window where you can spy and edit a few addresses manually.
But that does not work for large amounts of memory.
Any idea?
Thanks and regards
Loic
Any idea?
Thanks and regards
Loic
10:49 PM
Feb 07, 2017
10:49 PM
you should look into the linker script (*.ld file in the project root).
there you would need to load the pattern BEFORE things like stack and bss are loaded (partially overwriting your pattern).
