DAVE™ Forum Discussions
User13960
First like received
Hi everyone,
Is it possible to display the execution time of sections of code within DAVE 4 ?
For example the time to execute a function.
Thank you very much
PHAB
Nicky
5 replies posted First solution authored First reply posted
You can toggle an output at start and end of your code. This way you can measure with a scope how long it takes.
good luck.
jferreira
First like received 750 replies posted 500 replies posted
I would recommend the following post at interrupt memfault blog, https://interrupt.memfault.com/blog/profiling-firmware-on-cortex-m
User13960
First like received
Jesus, thanks for the blog link. Have you tried this method on the Infineon XMC parts ?
NIcky, thanks for the suggestion, it's exactly what I do normally. It's very reliable but means modifying code with the risk of forgetting to delete it prior to code release and it finding it's way into production.
PHAB
jferreira
The cycle counter is an standard feature of all ARM Cortex-M4, therefore all XMC4 support it.
For XMC1 you can go with the system timer which runs at the same frequency as the CPU, although it is "only" 24bit timer.
User13960
First like received
Thanks Jesus.
