DAVE™ Forum Discussions
Anyone had this one, and know a solution?
My 'HW Signal Connectivity' tab, has stopped showing the connectivity diagram, and starting saying as follows:
No Diagram found for URI 'file:/C:/Workspaces/DAVE-4.3-64Bit/ ... /Project/Dave/Model/hw_ProjDiagram.dep#/0
Well, it actually says that twice, in two windows, one on the left, one on the right, each with horizontal scrollbar, and central divider.
Would show you a pic, but don't have enough forum points to do so, last few times I've checked, anyway.
I've tried Run Solver, and Generate Code, also DAVE exit and restart, Windows close and reopen.
I think I'll need to start digging back through backups, to find one that still OK, then wind forward from there.
I think all the connectivity is fine, my app works, just, the diagram's gone, for some reason..
Anyone know how to get it back ?
David
jferreira
First like received 750 replies posted 500 replies posted
Hi David,
Could you share the .log file to be found in .metadata folder in your workspace?
Hi Jesus,
Sure, I'll send that straight through to you.
Thank you,
David
