I would like to generate a binary program with DAVE 4 in order to calculate the CRC32 of my project.
what I do :
Then, I build project to generate .bin, but In folder Release I just have .lst and not .bin
How can I have this file ?
Already thank you,
Pierre Gachet
Hi @gachetp ,
>>That means in debug we are not able to generate binary ?
We can generate a binary file in debug mode also.
Please follow the steps mentioned in the previous responses after you change the configuration.
Hi @gachetp ,
You can find the .bin files under the release section in your project.
I have attached an image below for reference.
Hi @Alakananda_BG,
thank you for your reponse, but I don't have the file .bin in my folder. it's why I ask ...
I don't have in Dave, so I look directly with the cmd to see if the file is cached.
But it is not present here also.
I have the impression that the .bin is not generated.
Hi @Alakananda_BG ,
Yes I have the command line but I change some parameters :
- ${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX} ${OUTPUTS}
Into
${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX} ${ProjName}.bin ${INPUTS}
it is correct to do that ?
I also put binary for output.
Thank you for your time you spend with me,
I appreciate,
Pierre Gachet.
Hi @gachetp ,
Can you use the same command line pattern as below and try
${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${INPUTS}
Hi @Alakananda_BG,
I just try and it change no thing. I don't find file .bin in the folder Release ... It's inapprehensible ....
Pierre.
Hi @gachetp ,
Can you share your project so that we can fix the issue and send it.
Hi @Alakananda_BG ,
I find the solution. Thank you for all your information.
So I download the last version of DAVE 4.5 but it change nothing. My problem is that I create a new configuration :
but when I configure I choose Existing configuration : debug
Now I use release, to copy the config and it's worked. That means in debug we are not able to generate binary ?
Thank you for your help,
Pierre Gachet.
Hi @gachetp ,
