DAVE™ Forum Discussions
who can help me finding the App configuration data?
It must be stored somewhere within the project directory but I can not locate it anywhere.
I have problems after changing some App parameters, the file Dave3.h contains the content of CAN001_Conf.h.
Which then includes again Dave3.h which ends up in an endless include loop.
making clean, call the resolver and code generator does not solve this issue.
I hope that I can repair it by editing the app configuration file.
User8819
Level 4
Level 4
application data are located in DAve\Generated\src\can001\can001_conf.c
rum
but what I'm looking for is the information used by the solver and code generator. I like to use the app configuration data, e.g. the CAN controller configuration, in a new project and hope I can copy it from one to the other. I can imagine it is stored somewhere in XML or other text based format.
Hi Heinz,
"Copy and Paste App configuration data" is not supported in DAVE 3.1.10. However, it will be supported in the next major release of DAVE.
Sophia
