Feb 15, 2016
10:52 AM
Feb 15, 2016
10:52 AM
Today we released new versions of DAVE, DAVE SDK, DAVE APPs, XMC Lib Device Descriptions, and Device Support Pack.
DAVE v4.2.2 and DAVE SDK v4.2.2:
Major improvements in comparison to the previous version (v4.1.4) are:
DAVE APPs:
New DAVE APPs have been added to the contributed update site:
Device Descriptions:
XMC Lib peripheral libraries (v2.1.4):
Device Support Pack (v2.1.4):
Example Projects:
The example projects are also updated to the new APP version. They are accessible form DAVE now. However, it may take a day or so until they are visible on the web example portal
Further Information:
More details about this update and how to install them can be found here.
Next Update:
Next full update is planned by end of April 2016.
- Fixing of issues and performance improvements.
- Separate installer for DAVE, DAVE SDK and windows 32-bit / 64-bit
- New functionalities, like mirroring of GUIs from required DAVE APPs to the requiring APP or new project setting options.
DAVE APPs:
- 8 New APPs are added (Ethernet support, EtherCat support, File System and new APPs for pure peripheral configuration)
- 22 APPs have been improved (e.g. ADC_MEASURMETNT_ADV, BUCK converter APPs, Clock APPs,…)
- Fix of issues
- I2C_CONFIG
- DAVE APPs for the TLE98x families
- Device Description for XMC4300 are added.
- All Device Descriptions have been improved to increases solver performance for some transactions
- 1 new library for the EtherCat module has been added.
- Support for XMC XMC4300 added.
- Enhancements and fixing of issues.
- Device support for XMC4300 has been added and some minor issues in startup and header file have been fixed.
Example Projects:
Next Update:
Labels
02:46 AM
Feb 16, 2016
02:46 AM
I did a clean install of the 64-bit Version and there is no Ethernet App showing up for the XMC4800/XMC4700.
Check for updates shows the following error:
Some sites could not be found. See the error log for more detail.
No repository found at http://dave.infineon.com/Luna/v4.1/Doxygen.
No repository found at http://dave.infineon.com/Luna/v4.1/64Bit-ARM-GCC.
Install new software window shows:
I am also curious about the 4.1 Version numbers.
As I said. It's a plain new install after deinstalling the DAVE 4.1.1 Version.
08:44 AM
Feb 16, 2016
08:44 AM
I got a question concering the example projects. I am searching the USBD_WINUSB_example, but it isn't visible on the web example portal. Will this app be uploded soon? Or is there a similar app?
Markus
Markus
Feb 16, 2016
10:52 AM
Feb 16, 2016
10:52 AM
Answer to HRush,
The issues with the two missing plug-in links will be solved soon, there is no functional issues associated with them.
The reason why you don’t find the ETH_LWIP APP is most likely because the new APPs haven’t been installed yet. (The installer install only a new library store if there isn’t one in location: ..\Users\
Feb 16, 2016
10:30 PM
Feb 16, 2016
10:30 PM
After updating to 4.2.2 the issue with not working key combinations (e.g. CTRL+H) and with
disappearing icons (e.g. back) in the toolbar, when changing the view, still exists.
Very annoying.
Will do a clean install and pray...
Michael
Very annoying.
Michael
12:14 AM
Feb 17, 2016
12:14 AM
Thanks for the answer with solution Georg.
