04:37 AM
Feb 25, 2016
04:37 AM
Hi everybody,
I'm using Dave 4.1. I was adding Apps in my project, when I got thi error: "Dave is not able to grant your last hardware resources request".
Does anybody ever dealt with this problem?
Thanks in advance for any advice.
Andrea.
Andrea.
05:43 AM
Feb 25, 2016
05:43 AM
I also tried to debug and I get a further error: " Error while launching command: C:\Davev4\Dave-4.1.4\eclipse\ARM-GCC-49/bin/arm-none-eabi-gdb --version".
06:09 PM
Feb 25, 2016
06:09 PM
HI Andrea,
Can you provide more details to your problem.
1. The current DAVE version that you are using. The latest version is DAVE v4.2.2, can you please do an update to the latest version.\
Instructions to the latest DAVE version: http://www.infineonforums.com/threads/3788-Feb-15-2016-New-Release-of-DAVE%C2%99-DAVE%C2%99-APPs-XMC...
2. Normally, the message "Dave is not able to grant your last hardware resources request" pops up when the hardware resource requested is already reserved.
Is the project with other DAVE APPs? Can you try to create an empty DAVE CE project and add DAVE APP to it?
Let me know the pop-up you see. Also, can you following the steps in the following link to retrieve the log file and add to this link.
http://www.infineonforums.com/threads/3400-DAVE-TIP-of-the-day-Extracting-the-DAVE4-logfile-(.log)-f...
Daryl
Daryl
03:03 AM
Feb 27, 2016
03:03 AM
Thank you Daryl for the suggests.
I upgrated Dave to 4.2.2 and I followed the steps from the link, but I continue to get this pop up error:
06:35 PM
Feb 28, 2016
06:35 PM
Hi Andrea,
Can you please send me your log file to have a look what is wrong with your setup.
Just in case, here's a quick start guide to DAVE. Were you able to launch up DAVE to create a new DAVE CE project?
http://www.infineon.com/dgdl/Infineon-DAVE_Quick_Start-GS-v02_00-EN.pdf?fileId=5546d4624cb7f111014d0...
If still note possible, can you please follow the steps within link, to send us your log file. Also, note when attaching, please zip up the .log file.
Daryl
Daryl
01:38 AM
Feb 29, 2016
01:38 AM
07:30 AM
Mar 01, 2016
07:30 AM
HI Andrea,
This is extracted from the log file. It shows that there is an error when launching the command. Can you check if the path listed below is valid.
!ENTRY ilg.gnuarmeclipse.debug.gdbjtag 4 5012 2016-02-29 10:06:24.791
!MESSAGE Error while launching command: C:\DAVEv4\DAVE-4.1.4\eclipse\ARM-GCC-49/bin/arm-none-eabi-gdb --version
Daryl
Daryl
