09:56 AM
Feb 08, 2013
09:56 AM
If eclipse is used to open a DAVE workspace it can corrupt the DAVE projects so that DAVE no longer recognizes the project as a DAVE project.
The project should be protected, so that if opened in Eclipse the settings that are DAVE specific cannot be modified.
The reason to do this is DAVE is only usable on Windows, while Eclipse can be used on many platforms.
Feb 18, 2013
12:08 PM
Feb 18, 2013
12:08 PM
Which Eclipse version are you using that shows the corruption you mentioned?
01:18 AM
Feb 19, 2013
01:18 AM
i faced the same issue yesterday, please try to close the project and re-open it, issue may will be solved~
01:20 AM
Feb 19, 2013
01:20 AM
Hi Huba, i also face some issue for the multi-ADC set up, kindly take a look the link as: http://www.infineonforums.com/threads/350-Issue-for-ADC-set-up-based-on-XMC-4500-relax-development-b...
many thanks!
many thanks!
05:11 AM
Feb 20, 2013
05:11 AM
Juno and Helios.
The issue occurs when modifying eclipse project settings.
Feb 21, 2013
11:12 PM
Feb 21, 2013
11:12 PM
DAVE tool was built on Eclipse 3.7 (Indigo) with latest updates (Stable releases)
PS:
1. There is no compatibility between ‘Juno’ and ‘Indigo’, Juno’s (4.0) entire source code base has been changed.
2. ‘Helios’ is Eclipse (3.6) which was doesn't have all the updated features which were used in DAVE Tool
PS:
08:27 AM
Feb 27, 2013
08:27 AM
Are you saying that DAVE projects will be preserved on Eclipse 3.7 regardless of the operating system it is run on?
My use case is the DAVE project is referenced by other eclipse projects.
In order to have all projects operate in the same way some settings that cannot be set at the Workspace level must be set at the project level.
I would like to be able to change the settings using Eclipse 3.7 on a mac, without making the DAVE part of the project unusable.
