E_EEPROM_XMC4 protect memory from being over-written during flash programming
User13960
First like received
Hi all,
I am planning to use the E_EEPROM_XMC4 App to store a non volatile variable in FLASH memory. The variable will be written once in the product lifetime (it is a license key)
Is it possible to protect the variable from being over-written while updating the firmware via flash programming when using a a programming tool like XMC-Link / XMCFlasher or Mini-Wiggler / DAVE IDE
In other words how do I locate the variable in a location that flash programming won't reach.
Thank you in advance
PHAB
jferreira
10 sign-ins 5 sign-ins First like received
You can use the write protection feature of the FLASH sectors.
See Flash Protection in the reference manual and the related XMCLib functions in xmc4_flash.h
