DAVE™ Forum Discussions
User7795
Level 4
Level 4
Hi Infineon,
gdb doesn't display global vars at all stackframes, function always is greyed out.
Wolfgang
ningareddy_moda
Hi Wolfgang,
This feature is not supported from CDT framework itself.
Please see the defect entry
https://bugs.eclipse.org/bugs/show_bug.cgi?id=219040
“Instead, you can add the ones you are interested in within the Expressions view”
Best Regards
Ningareddy
User7795
Level 4
Level 4
Hi Ningareddy,
thanks for this hint, some more details:
if the expressions tab doesn't exist, go to window -> Show View and click on Expressions, then the expressions view tab appears at variable view (top right). To display a global variable click on then green "+" and enter the name of the variable, then the value appears. To expand arrays, click on the "+" box.
Wolfgang
Here are additional infos:
http://mcuoneclipse.com/2014/03/16/variable-debugging-with-eclipse-kepler/
