CasadoRa
DAVE 4 provides an APP to obtain a PWM signal generated by a Space Vector Modulation (PWM_SVM). The APP Help mentions that it is suitable for XMC1302 but when implementing the example given in APP Help > Usage, there is no SV Modulation. After debugging there can be seen that the following function: void PWM_SVM_SVMUpdate ( PWM_SVM_t *const HandlePtr,uint16_t Amplitude,uint32_t Angle) there is no change in the entered amplitude and angle values.
Hope that anyone had the same problem and knows the solution.
Aitor
User20891
I'm having the same problem...any luck?
