03:52 AM
Mar 26, 2018
03:52 AM
I have created a new Dave CE Project in Dave 4.4.2 and it occurs to me that the Memory Settings Page is missing.
Is that an intentional change of the GUI or is this a bug?
Apr 24, 2018
12:05 AM
Apr 24, 2018
12:05 AM
Hi Val-R!
Indeed window is read only.
You could modify Memory under
select by right mouse key your "Project[Active-Debug]" and step to "DAVE PROJECT UPGRADE", select "DEVICE UPGRADE" ; here you could select another µC but don't forget to select "MIGRATE".
If you intend to enable printf or scanf, it is possible to do this under
select by right mouse key your "Project[Active-Debug]" and step to "PREFERENCES", select "C/C++ Build" --> Settings-->ARM-GCC Linker -->General --> mark your options
Apr 25, 2018
06:46 AM
Apr 25, 2018
06:46 AM
I think the OP is referring to the fact that certain Help documents such as the EMU EEPROM call out the "Memory Settings" page to change the memory region allotted for program space.
So since that is no longer located there, either the document should be updated or this menu item be added to match the documentation in v4.4.2.
Now of course the linker file could be edited manually, but the documentation does not even mention the linker file.
Mar 12, 2020
02:14 PM
Mar 12, 2020
02:14 PM
Hallo Armatron
hallo All,
I am falling into the same problem: there is no "Memory Settings" option in DAVE 4.4.2, so I do not know how to configure the starting address for the EEPROM EMULATION.
Furthermore, do you have any working example to share with me?
Thank you very much for your kind reply.
Ciao
Fabio
hallo All,
Ciao
Fabio
Mar 16, 2020
04:21 AM
Mar 16, 2020
04:21 AM
See E_EEPROM_XMC1_EXAMPLE_XMC13 in https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html or the help documentation of the E_EEPROM_XMC4 APP usage section.
