DAVE™ Forum Discussions
I have a Dave3 project using XMC4500 100x1024. I generated the Keil project from it and the debugger works fine in Keil.
But switching back to Dave, i get this error exception when starting to Debug.
Even if i removed the RTE folder which is needed by Keil, i get the same error.
Do you know what could be the root causes of that?
HI,
Was your original DAVE3 project able to be debugged?
Also, are you using the generated .gpdsc in DAVE to run your project in Keil?
Daryl
