08:17 AM
Mar 30, 2015
08:17 AM
Hi all,
Is there a way to convert DAVE3 code to keil without the need to generate the code? Because I've changed some values in registers etc and if I generate my code I would lose all my changes.
Thanks in advice.
Thanks in advice.
03:47 AM
Mar 31, 2015
03:47 AM
You can place your code in main.c so that it will not be overwritten upon re-generation of the code.
Sophia
Sophia
04:21 AM
Mar 31, 2015
04:21 AM
thanks for your answer. I have another question.
When I'm imported DAVE3 code in keil 5 and I want to build than I get the following error: cannot open source input file "uc_id.h": No such file or directory
06:18 AM
Mar 31, 2015
06:18 AM
my program is working in DAVE3 but not in keil.
12:45 AM
Apr 01, 2015
12:45 AM
To clarify:
1) Did you follow the tutorial for importing the DAVE3 code into Keil?
2) Are you using Keil UV5.12?
Sophia
To clarify:
Sophia
02:26 AM
Apr 01, 2015
02:26 AM
1) Yes
2) Nope, Keil µVision V5.14.0.0
1) Yes
02:27 AM
Apr 01, 2015
02:27 AM
is there another way to import dave code in keil without the need of generating code?
12:56 AM
Apr 02, 2015
12:56 AM
You need to supply the path to the uc_id.h file and RTE folder in Keil (see attached example).
Sophia
Sophia
01:26 AM
Apr 02, 2015
01:26 AM
Yes, I've already did this... The problem to me seems that the program is not generating the SPI clock... But it works in DAVE3, so I just don't get it.
Thanks in advice.
Thanks in advice.
02:30 PM
Apr 30, 2015
02:30 PM
hi sohia how are you?
i have follow your tutorial import from dave 3 in to keil but still failed i see in Keil
C:\DAVE-3.1.10\DAVE-3.1.10\CMSIS\Infineon\Include\uc_id.h(42): error: #13: expected a file name
#include “RTE_Components.h”
advice please because we will running production with xmc1100
thanks regard.
Irfan
indonesia
thanks regard.
Irfan
indonesia
02:33 PM
Apr 30, 2015
02:33 PM
thanks regard.
Irfan
indonesia
thanks regard.
Irfan
indonesia
07:29 PM
May 03, 2015
07:29 PM
Hi Irfan,
Because "uc_id.h" is no more used in DAVE4. So, it is removed from device header files in new PACK . You need to add this file manually.
Did you try to follow the work around solution (2nd Apr post) to supply the path to the uc_id.h file and RTE folder in Keil?
Sophia
Sophia
May 28, 2015
02:07 AM
May 28, 2015
02:07 AM
Since you are using DAVE3 project in KEIL5.x, the start-up file for the device may be latest one in the KEIL device pack(may be version 2.x.x).
This start-up file, will have some changes for the clock configuration in DAVE4.
For DAVE3 to KEIL5.x, user has to use the KEIL pack version 1.x.x
As a temporary solution once you export DAVE3 project in to KEIL 5.x, you may use the system_xmcxxxx.c from DAVE3 project to get the proper peripheral clock.
Nisheedh
Nisheedh
