Dec 19, 2012
06:39 PM
Dec 19, 2012
06:39 PM
I met two Issues.
1. DAVE3 is often 'no responding' and has to be restarted, when bebugging and downloading as follow picture.
2. I defined an Array[128], but only 100 data can be seen in the variable view of debug perspective.
How to show the all? BTW, is there any other method to export these data to Excel( for example), except "select all -> copy -> paste"?
04:04 AM
Dec 20, 2012
04:04 AM
zhangpin wrote:
I met two Issues.
I frequently get this as well. I found that in the Debug pane if you methodically do "suspend" then "terminate" and then choose "remove all terminated" it may occur less (but I might just be imagining this!).
Andy
Feb 11, 2013
01:00 AM
Feb 11, 2013
01:00 AM
We are working with Altium to get this sporadic problem solved. An improved debugger version is planned to be published with the next DAVE release planned by Feb, 22nd.
Georg Huba
Georg Huba
