Jan 25, 2019
08:31 AM
Jan 25, 2019
08:31 AM
I'm using DAVE Version: 4.4.2 on an XMC4800 project. I can't get the memory monitor to show the variable/address I need. DAVE seems to remember some address I looked at a few sessions ago & only display that address.
What am I doing wrong? I've used Eclipse for years on various Android & firmware projects, usually I click the + sign, type in my hex address and there's the data. DAVE doesn't show any data until
I double click on Hex in a rendering window and it displays some random address I looked at many sessions ago.
10:50 PM
Jan 30, 2019
10:50 PM
Maybe it helps if you change the debug configuration file location. See in the picture below I'm using a shared file located in my project.
PS: Otherwise, it depends on your preferences, but I always recommend the usage of external debuggers like Segger Ozone or iSystem winIDEA.
