DAVE™ Forum Discussions
Since DAVE is based on eclipse i was wondering if MALAB can be integrated into DAVE?
i was able to find one such plugin into eclipse called matclipse
https://code.google.com/a/eclipselabs.org/p/matclipse/source/checkout\
was wondering if it can be done with DAVE also or is there any other way?
Sorry, I'm not very clear about the integration you mentioned. The link is not working. But you can try to install the plugin in DAVE (Go to: >Help>Install New Software...).
Sophia
