02:33 AM
Jul 17, 2013
02:33 AM
The local library store is a place in the where to store downloaded DAVE Apps and Example Projects.
The default folder is “D3LibraryStore” which can be found in C:\Users\\Infineon\
The default location is defined in >Windows >Preferences >Dave >Library Manager which can be changed. After changing, DAVE3 has to be restarted to make the change effective.
1) Working with different library stores is a way to keep different DAVE Apps (versions) separate;
2) It is recommended to empty the local library store before installing the updated the DAVE Apps.
