The Infineon DAVE Project import/export function has to be used for all project import/export actions, it can dereference/reference included and library path to the new workspace. Otherwise, the DAVE relevant information may not be imported/exported correctly.
For example, if using General import function, project with DAVE App modification might not work properly after rebuilding.
In addition, you can use import function to copy all or selected projects from an existing workspace into a new workspace. Do remember to keep "Copy Projects Into Workspace" being checked.
1) Infineon DAVE Project import function:
Go to: > File > Import > Infineon > DAVE Projects
2) Infineon DAVE Project export function:
Go to: > File > Export > Infineon > DAVE Projects
3) General import function:
Go to: > File > Import > General > Existing Projects into Workspace
