03:16 AM
Oct 18, 2013
03:16 AM
You can easily migrate an existing project with older DAVE App versions to newer DAVE App versions by using "Apps Migration" function provided in DAVE v3.1.8.
If the latest DAVE App version in the local library store is newer than the same DAVE App of the active project, then the respective DAVE™ Apps of the active project will be replaced by the latest version stored in the local library store. All relevant setting from the old DAVE App version will be copied to the new version.
It is recommended to backup a copy of the project before starting the migration process.
Details can be found in DAVE User Manual:
Go to: >Help>Help Contents>DAVE User Manual>App and Device Migration
