This looks like a overflow issue. Can you check whether the variable address from map file and check going to that address ? Additionally as this overflow could happen in run-time we are unable to track that.
Vasanth
To understand the question more, are you facing the issue only when you try to see the variable on debug ? Is the project building without any problem ? Also could you kindly provide a screenshot on what you see at your end and the pseudo code to recreate the issue ?
Vasanth
Vasanth
