Hi, ALL
I need to change the HW signal connect and Pin allocation (according to the key state) when the system is running. So how to achieve this function on the code level? Coulde you provide an example about this application?
Wish to get your help. Thanks!
Hi @DeXi_1316761 ,
Can you refer to the below code examples and let us know if that helps.
https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html
Hi @DeXi_1316761 ,
Can you let us know what do you mean by hardware Signal Connect?
HI, @DeXi_1316761 ,
I want to change the systerm connection according to the config key, to achieve the flexible configuration.
(1) In code, I need to change the input(CINA or CINB) of the COMP_SLOPE_GEN APP according to the extern key stae. How to do this by API function?
(2) In project, there are one COMP_SLOPE_GEN and two HRPWM. I want change the target signal (HRPWM_0 or HRPWM_1)of the COMP_SLOPE_GEN comp_out_to_hrc source singal. How to do this by API function?
Wish to your reply. Thanks!
Hi @DeXi_1316761 ,
HI,
Thanks! I will to view these examples.
