- Email to a Friend
in Windows 11 ,I'm not able to modify an assigned pin (see the picture below)
with Windows 10 it works
- Email to a Friend
I confirmed the Dave 4.4.2 and 4.5 IDE s are tested to work until Windows 10 versions. Unfortunately this support extension will not happen for Windows 11 or future windows version. But on the other hand ModusToolbox will be taking care of future support for XMC.
From release notes of 4.4.2
From the release notes of 4.5,
Thanks for your understanding.
Vasanth
- Email to a Friend
Are you getting the error when you try to open manual pin allocator? In your screenshot I am seeing project properties and Micro-controller info in the background. Can you tell me what were you trying to there?
Vasanth
- Email to a Friend
When I try to change the pin assigned to an APP, the following window appears:
in which the allocated pin is not seen and cannot even be set.
at the same time, errors are reported to me:
So I went into the project properties to check the microcontroller and I get this message:
If I try to upgrade the apps I get this message:
and if I try to do the device migration no window opens
- Email to a Friend
Vasanth
