02:19 AM
Feb 22, 2017
02:19 AM
I tried using the DAC_LUT app under Dave 4.3.2 but the app keeps crashing. I use the 'XMC4700 relax kit'. The "normal" DAC app works just fine so I assume it is no hardware issue.
I set up the DAC_LUT app exactly like described in the help file under "usage" - no changes in the main.c file. When executing the code I can see (on the scope)
the DAC output changing one increment - than the processor hangs up. Does anybody else experience similar issues?
Thank you!
Thank you!
02:37 AM
Feb 22, 2017
02:37 AM
Well this is embarrassing - I had set up the XMC4500 processor. With the correct processor selected the app works just fine. Please ignore/delete this Thread.
