DAVE™ Forum Discussions
User5327
Level 4
Level 4
Hi all,
How can I set Rounding mode for data type conversion (float to integer) ?
Is it possible?
float f_var = 1.6F;
int32_t i_var = 0;
i_var = (int32_t)f_var;
sometimes I need i_var == 1 another time I need i_var == 2
(I use XMC4500)
Is it same as in http://www.infineonforums.com/threads/2096-float-data-type
BR
Koumak
Hi Koumak,
One method for your example is to add 0.4 before casting if you want to round up...
i_var = (int32_t)(f_var + 0.4);
But if you want anything above 0.5 to round up then add 0.5 first
Aaron
