Communicate with XMC4500 relax lite kit v1 over usb
Hi all,
i am a beginner in programming and got a problem i stuck quite long on. i want the microcontroller to tell me the value of a variable. I am using usbvc001 for getting the information (USBVC001_SendByte(). To display the information i use TERMITE Terminal, but i cant build a connection to the microcontroller. I got the COM port from the device manager and set the same bauld rate. I'm quite new nad i am happy for every solution 🙂 I hope someone can help me! (sry for my bad language)
Hi Nathan,
Unfortunately the XMC4500 relax lite kit v1 doesn't support VCOM as per "DAVE TIP of the day: xSPY solution for XMC kits".
In addition, you should use USBD_VCOM App instead of USBVC001 App (refer to "Problems with USBVC001 App" 11-Aug post).
BR,
Zain
WilhelmBrezovit
First solution authored Welcome! 10 replies posted
Dear Platin,
In the attachment you will find an example how it is working 🙂
Please have a look at page 11 – you have to install the USB driver.
All the best,
Wilhelm
Thank u so much!! This fixed my Problem! i played around with the driver and the device manager but i didn't find the solution! Thanks again :DDD
