Apr 06, 2014
12:03 PM
Apr 06, 2014
12:03 PM
I wonder if there is a way to compile a much more compact code (smaller size), since it happen that the Flash size is not enought on my XMC1100. Any hint?
- dave general
08:21 PM
Apr 06, 2014
08:21 PM
Not sure if you have done this but you can removed the unused section of the code.
Just go to Project Properties -> Settings -> ARM-GCC C Linker -> General and checked the box for "Removed unused sections'.
10:59 PM
Apr 06, 2014
10:59 PM
The optimization options are addressed in "DAVE TIP of the day: DAVE Optimization settings" & "DAVE TIP of the day: Option to reduce the code size".
Sophia
Sophia
