Changing the heap size in XMC4000 in DAVE
noureldin3010
I'm currently programming the XMC4400 MCU using DAVE ... how can I change the size allocated for the stack and heap memories?
Vasanth
Hi ,
Kindly check linker_script.ld file in the file structure. This has both heap and stack information of the project which you can edit according to the requirement.
Vasanth
Vasanth
Hi ,
Vasanth
sujatapatil
50 solutions authored 10 likes received 100 sign-ins
Hi ,
Dave project properties does not have settings/configuration for memory start address , end address , stack/heap size similar to Keil IDE or any other IDE you are referring  in project properties .   Instead it is defined in separate file which is linker_script.ld . So to  have heap size alone as part of project properties  also does not make sense.
Each  IDE can have it's own appearance and properties.
Sujata
